Fizlam
Hello,
First time poster.
I recently inherited a 2008 FZ6 with 11k miles. The bike sat for a few years before i got it. It was in good shape... this is what i did before getting it going.
-Replaced the battery
-Changed fluids (oil, coolant, brake)
-Drained and replaced old gas and thoroughly cleaned out the tank
-TPS checked and all within spec
-Warmed-up idle set to about 1200rpms
The bike fired right up with new/clean gas, I did a number of short initial rides and the bike ran good, but stalled out a couple times (always fired back up). Turns out the fuel pump was bad, would intermittently stop... so I swapped it with a new Fuel Pump Factory replacement and OEM O-ring. I completely cleaned the gas tank out again before putting the new pump in. Never stalled again after that.
The only other thing I replaced was the ignition coils... because I noticed that it had a bit of a misfire/rough idle.
I came to that conclusion after forum and Youtube searches. I got some used ones off eBay, replaced the plugs at the same time, and it seemed to idle/run perfect after that.
I did quite a few more short (10-15mi rides) and the bike seemed flawless. Smooth acceleration in every gear, all the way to redline, smooth idle. Went thru a full tank of gas on short rides with no problems. Always got the bike up to temp on these rides.
Anyways, I finally did a longer ride yesterday (about 50mi). Functioned awesome throughout the entire powerband in every gear, all the way until the last 3 miles or so.
Right at the end of the ride (going up a hill), the bike would hit a brick wall around 4-6k rpms when accelerating in any gear. It wouldn't completely die.. and when i backed off the throttle the lower-end (idle to 4k rpms) it ran fine.
If i tried to keep accelerating beyond 4-6K, it would practically die. Theres plenty of gas left in the tank.
Avg operating temps on that ride was like 180-200F (got higher when stopped). It was a pretty warm day (mid 70s)
Do you think the used coils i got off eBay might be failing when the bike gets hot?
I'm kinda ruling out a fuel delivery problem at this point, because the fuel pump is new, the filter screen is clean. I ran Seafoam and the bike still accelerates perfectly to redline when cold/warm... so i doubt the injectors are obstructed/clogged. I haven't gone on another longer ride since, so i haven't been able to make the symptom happen again. It didn't repeat the problem on a 10mi ride i just did (tried to get the bike as hot as i could).
thanks for any guidance and responses.
-Fizzle
First time poster.
-Fizzle
