Left out bike for a 2 months, starts up but bogs down when revving and idiling.
also adding on the last bit of the fuel was all white like likely water was added. I took off the tank and i’m allowing it to dry.
That did the trick !!! It works like a charm, however my dumbass may have screwed the fuel filter back on wrong ? I noticed it was leaking drop by drop. Any suggestions?
I don't remember as it's been well over a decade since I replaced the tank.
I believe theirs a flat side on the seal/ tapered on the other side.
The flat side of the seal goes on the pump first. It should seat fully. Then install the unit in the tank..
yeah i tried lining it up as best as i could, i hope it stays in place. It would suck to take all the fuel out and pump apart again
seems to have worked, getting a lot of white smoke though nit sure if it’s just because it’s cold or what but i washed it all with water invase any fuel got into the exhaust pipes when i was taking the fuel out. If that’s the case than i’ve fixed it
Your cam chain tensionor may near the end of it's travel, or the chain guide may be worn. Like I said, these engines have loud cam chains and it's hard to tell from the video clip if yours is unusual. This is something that can be looked at and addressed during the 25,000 valve check service. If you think its too loud, just have the valve service performed a little early.
got it, thank you! any dangers of riding while it’s like that ?
A broken timing chain = garbage engine. The pistons hit the valves...everything bends...garbage.
Like I said, I can't tell from the video if it's unusually noisy. Maybe bring it to a Yamaha dealer (around the back where the mechanics are) and ask a mechanic. With that said...you are "in the zone" for a valve adjustment. Checking the guide and tensionor is part of that process.
