toybox
I have tried to understand my clutch slippage in the past, but even after I adjusted the clutch cable and replaced the clutch plate the problem still occurred. I am currently planning to replace the clutch cable as well as the spark plug.
I often encounter malfunctions in second gear. It's like the power is suddenly cut off and reengaged, more than once.
I once encountered it in third gear, but at that time I was not sure if it was really in third gear. At present, I think that if the clutch is not slipping, maybe my second gear is worn and the ECU has an error in judging the second gear signal (the wiring harness may have fallen off or Short circuit) one of them since I didn't have the problem in the other gears.
Is there anything else I haven't noticed? I hope seniors can tell me what I missed.
