I'm going to have to dig into that link more.
When I got mine, I have what appears to be a standard FZ1 mounting bracket, rigged up to fit. There was some form of sheet metal fabricated to be attached to the bracket to hold the instrument cluster. There was no vibration elimination so after a few 10 thousand miles, it had succumbed to metal fatigue and started to break apart.
I replaced it with another piece I fabricated with some aluminum commercial roofing flashing. I was able to add some vibration reduction, but it is not free completely, so It does rattle on some of the regular hard bumps and will probably eventually succumb to the same fate. I don't really have any pics that show the fabricated piece well, or the mounting bracket at the moment. Maybe I'll get some next time I take anything apart in that area. These are the closes I have.
I've seen that there are bracket, headlight, turn signal kits available on Amazon. They follow the look of the FZ6 headlight with the middle top being pointed up, if you like that look.
