Posted by krid80 on Novemeber 5, 2008:
"don't waste money on a power commander (pc3) on a yamaha! a fifty cent piece of wire, ring terminal and a pin connector will get you the same power so long as you dyno tune.
There is a six pin connector under the tank where on one half, six wires come in and only five come out. Separate the plug halves and push out the rubber stopper covering the unused terminal. run the new wire from that terminal to a good ground and you are ready to adjust.
adjusting is simple! hold down the select and reset buttons for a couple seconds with the key off then turn the key on while holding the buttons for about 7 seconds more. "diag" should appear on the display. press select to switch to "co" then select and reset simultaneously to select "co" mode. adjust "c1" and "c2" the same increments up (write down your factory settings) while dynoing until your power starts to fall off. "
There are more detailed posts on this subject if you spend some time searching. In short the grounded wire places the ECU into a maintenance mode, allowing a technician (or you since you now have the keys to the ECU) to make adjustments to the fuel injector duty cycle. Note your starting point so you can get back to the OEM spec if needed.
Personally, I wouldn't undertake this without access to a wide band A:F and a dyno.
EDIT:
This appears to be the master thread on the subject. Once again, not required for a slip-on and air filter.
Just ran the FZ on the dyno for the first time with the Leo Vince exhaust. Here's the setup: 2006 Yamaha FZ6 with Leo Vince exhaust with cat eliminator, db killers out. Previous run totally stock 89.10hp Today's runs: Run 1 (stock tune) - 93.20hp Run 2 (+4 C1 and C2) - 93.82hp...
www.600riders.com
