gnyce
- Joined
- Nov 29, 2015
- Messages
- 336
- Reaction score
- 193
- Points
- 43
- Location
- north of Philadelphia PA, US
Bonus: you now have an engine to rebuild just for the sake of doing it. It’s a lot of work, but it’s not hard work and it’s not expensive. A few hundred for a gasket/seal kit, bearing shells are about $40/pair. Things like timing chain and CCT should be reviewed and measured.
The unrealistic-me wants to turn this engine rebuild from a 600cc -> 660cc. There are a few ways to do that, as detailed on the fzronline.com archives (one way being getting the top-half of a yzf600 engine). Down-to-earth me remembers that you must learn to walk before you run.
All that is left is - Airbox, gas tank/fuel pump, add oil... and replace starter clutch flywheel (chipped tooth), should be able to try to turn it over this wknd. Unfortunately the day job now intrudes.
