Ital
Hi guys could you help me figure out which bikes require the least amount of major maintencae, such as valve adjustsments?
The Fz6 was my favorite bike I wanted but the fact that it required the valves to be check roughly every 25k miles definetly help me not look at Aprilia and Ducati.
I was reading that BMW used to make a k engine that did not require valves to be checked but I believe that engine is not made anymore.
What other bikes out there require very little maintenance?
We shall start with teh
PERIODIC MAINTENANCE CHART
Honda Goldwing - Check and adjust valve clearance when engine is cold. Every 32,000 mi (52,000 km)
Yamaha FZ6 - Check and adjust valve clearance when engine is cold. Every 26,600 mi (42,000 km)
Kawasaki VERSYS 1000 - Check and adjust valve clearance when engine is cold. Every 26,600 mi (42,000 km)
Yamaha Tracer 900 - Check and adjust valve clearance when engine is cold. Every 25,000 mi (40,000 km)
Suzuki V-Strom 1000 - Check and adjust valve clearance when engine is cold. Every 25,000 mi (40,000 km)
Mv Agusta Turismo Veloce 800 - Check and adjust valve clearance when engine is cold. Every 18,000 mi (30,000 km)
Ducati multistrada 1260\950 - Check and adjust valve clearance when engine is cold. Every 18,000 mi (30,000 km)
Honda Africa Twin - CRF1000L - Check and adjust valve clearance when engine is cold. Every 16,000 mi
2015 HONDA Interceptor - Check and adjust valve clearance when engine is cold. Every 16,000 mi
HONDA NC 700X - Check and adjust valve clearance when engine is cold. Every 12,000 mi
BMW F700GS - Check and adjust valve clearance when engine is cold. Every 12,000 mi
