TommyT
Hi all! Hope everybody had a good christmas and new year - really hoping for some help here:
Bike operates fine under all conditons, no faults to report anywhere at anytime, apart from the following:
If I pin the throttle (not sure if any particular gear) the bike will accelerate like a beast, as normal, but suddenly jump, as if the rear wheel is losing traction (it’s not) or there is a tooth missing on a sprocket (there isn’t).
It is worth noting that if I DON’T pin the throttle and accelerate gently through the same gear/rpm/speed this does not happen.
I have new-ish tyres, tested in the dry aswell. I’ve inspected both sprockets and nothing is missing or hooked. Chain is of adequate tension and well oiled. What the hell is going on? I’m worried about this happening in the wet or on a corner. Obviously something is wrong...
2006 FZ6-N
Thanks in advance for any help offered.
2006 FZ6-N
