Dealsgapr6
What can be done about an excessively stiff throttle on an 06 FZ6? I'm going to try to lube the cables and take the assembly apart to see if there's any corrosion or gunk causing an issue, but it's basically impossible to make precise on off throttle inputs in any sort of sport riding scenario. I don't know if there is a return spring I can buy after-market that's lighter, or some other way to fix this issue. Searching around, I've seen this is a common complaint with this bike, but I've never seen anyone come up with a solution. None of the R6s I've owned have had this problem, so I'm wondering if it's just an inherently bad design with this bike. Any help appreciated!
