heath_AU
Hi All
Have not posted on here in ages. Have been having far too much riding of course
Well recently i had my baby girl (2008 FZ6N) start having an issue where intermittently (maybe 1 in 3) times when i would go to start her while she was warm/hot I get just a relay/solenoid click and NO cranking. While i hold the button down the check engine light appears but I think this is normal.
I figured out that if I put the bike in gear and rolled the bike back and forward turning the engine over slightly, it starts everytime (albeit slightly sluggishly)
I have a brand new battery (MotoBatt) and the last one of those was still perfectly good after 5 years of daily riding and as it starts perfect every time cold (and a perky start with no hesitation) i am convinced the battery is not the issue.
The bike unfortunately did endure some salt water in a freak incident once (had an ocean wave actually break over me while riding) and this triggered some unusually aggressive corrosion (yes i know now I should have washed her immediately) so it would not be a surprise to see some electronics failing prematurely.
She has 130,000km on her and has been frequently serviced so I am thinking either the starter relay is playing up or (more likely) its the brushes in the starter motor (which would explain the rolling/turning method of starting her)
Any thoughts?
I have removed all the wiring for both the starter and main relay/fuse and cleaned them (much oxidation material was removed) but this yielded no change
Cheers
Heath
Any thoughts?
Cheers
Heath
