Oh, didn't mean to cause you trouble
Putting brake oil the first time was a pain and it was full of air bubbles - lots tiny air bubbles coming out - think carbonated drinks. Could be due to the new lines and changing the caliper seals at the same time. Gave it a day rest and bled it again, this time with the left brake off the fork and hanging midway between the brake oil reservoir and the right brake. Went much smoother and the air came off easily. Only did one subsequent bleeding at the end of the season and did not have to unbolt the brake off the fork this time.
I would suggest asking them for a specific length of brake lines. I had checked a few brands at the time and their length was always longer than OEM, which would make the line miss the passthrough on the top of the fender. For some reasons, they all set the length to 1 to 2 inches longer. The length is a bit less important for the line that goes from the left brake to the reservoir as there is no passthrough that can be missed but I had that shorten as well so to avoid having too much cable 'hanging' + I had lowered the handlebar as well which also shortened the distance between the reservoir and the brakes. Venhill (the brnad I got) had no issue doing custom length, the guy said they cut the line when an order is place, not ahead of time. So custom length does not make any difference for them whatsoever. I had to order a couple of different angled banjos too to make sure I got it right and there were no weird angles. I can send you detailed pics (and better lit pictures too) if you think that can help.
That's funny you mentioned
the longer lines. I just literally got off the phone with Hel (great folks!) and talking with their technician.
I told him I needed the over the fender line ONLY, that I didn't like the looks of the dual lines. He mentioned that front, over the fender line was
22".
I happened to re-measure the stock line and its 19", NOT 22".
Needless to say, he asked for pic's, which I sent, and some of the ends at the master were different(one incorrect??) Pictured all of that for him.
Anyway, their going to call me back shortly after he see's my pic's and measurements and make me a 19" line. I can use one of the other two long lines up to the master...
And no, your post wasn't a bother. It looked crappy and should be right, so it will be soon... (Thank you!)
BTW, HEL apparently did have the over the fender lines back then, the option wasn't told or given to me at the time, bout 6 years ago..
I also asked re bleeding as sometime there's an issue with over the fender loops. As normal, start at the far caliper. Should you still have mucho air, either pull off the whole system and get it level or so to bleed or at least bring the far caliper over to work out the air...
