HI guys and gals,
A few weeks ago I had trouble with my clutch slipping, after reading a few posts I found how to adjust the bottom end of the FZS600 clutch and went ahead and loosened the lock nut and used a screw driver on the middle bit.
I turned clockwise until I felt resistance then backed out 90 deg as I'd read too and re-locked the nut but I'm still getting a bit of slip on hard acceleration altho it's much better than it was.
My question is, how much resistance should you feel before backing out 90 deg? From when you first feel the slightest resistance or firm resistance? there's nearly 90 deg between the 2 so this could be my problem.
Would it bite better if screwed further in or out?
Thanks in advance, hopefully I don't need a new clutch, she's done 24.5k miles what kinda life do you get from FZS600 clutch plates?
Cheers guys really appreciate you taking your time to read and/or hopefully reply
