cspan
My fz6 will not start in gear ? I have the clutch pulled in and the kickstand up. What should I look for ? Im pretty sure its a bad switch rely right ?
Thanks for the help.
Ours didn't for some time and now it does again. Which I find good. If you have to restart quick is a pain to have to go for neutral first!
Sent from my DROID RAZR HD using Tapatalk
noob question(have yet to ride my new fz)... why not just start it in neutral?
There's NO reason why you can't start it in neutral. You just want to make sure
you CAN start it in gear if need be (ie: stalled engine in traffic).
You don't want to be jambing up traffic and if someone comes flying up from behind, not paying attention while your searching for neutral to start, then shift into gear, there's several seconds your a target.... :thumbup:
ah ok, so basically to save time in an emergency by being able to fire up and go without fumbling for gears.. gotcha![]()
