This afternoons update... left work at 12, didn't get home until 3pm
starting to get to grips with it and learning to lean more as I'm more and more conscious of flat spotting my tyres through not riding the bike properly
After the ride I chucked the bike on the centre stand and thoroughly cleaned the chain with WD40 (well, a mechanics equiv
), it was filthy!! I then removed the front cover which came off a lot easier than I expected (thanks Scott!) and cleaned around/inside that area.... could not believe the amount of gunk, luckily I bought 4 garage paper rolls a few months back, probably emptied a quarter of a roll on this area alone
refitted, left to dry while i did other jobs before getting a fresh coat of Putoline DX11.
Next I switched the radiator fan fuse to 10 amp from the standard 20....I also had to refit the stone guard as the screws i used stopped the plastic cover seating properly at the bottom. So I made a complete new piece and fastened it further into the plastic guard.... fits loads better and flicks up above the manifold so its less visible, bigger and almost completely covering the fan area.
After this, removed the front fender - this now has the fender extender attached and is drying, ready for refit tomorrow.....
Last thing to do was to hide the wire going to my second headlight, after a less than neat install midweek - oh that and check my fluids/oil/lights.
All in all a pretty productive afternoon - tomorrow will consist of fender refit and chain tension check using this guide
How to adjust chain and rear wheel alignment - Yamaha FZ6R Forums - International FZ6R / XJ6 Motorcycle Community Forum the measurements are the same for the R too I noticed
(though we obviously have that in our manual) - Tyre pressures to be done - then it'll be ride ride ride! (I've a few mates that need visiting all of a sudden
Edit: One thing I have noticed, when changing up a gear, my boots don't let the selector drop fully, so i have to push my boots down before lifting up to another gear...otherwise the bike won't obviously change.... is it a good idea to move the selector up slightly, few mm's perhaps?
Tim
