Update:
I recently finished a frame swap on the bike, and got new tires (the rear tire was showing cables).
The pulling problem is largely solved, but not gone completely yet. The measurements that showed the frame was bad are fixed, and measure correctly now, so I am confident that those particular problems are solved. However, I checked further into the forks because of the slight drifting issue that remains (no amount of aligning the front end, or aligning the rear tire makes it go away).
The upper forks (shiny section where they normally bend), has around .002" runout on each side when spun inside the lower fork. However, one lower section has around .050" runout, possibly more.
I am realizing that whoever "rebuilt" this bike did not fully inspect/replace everything that they should have. I am thinking that they found a bent upper, maybe even both uppers, and replaced just those pieces, instead of brand new forks.
So far on this bike, I have found a bent lower triple, bent frame, and bent lower fork. Let this be a lesson-DO NOT BUY A BIKE WITH A REBUILT TITLE, it is not worth the initial purchase savings.
That being said, I am committed to this thing by now, and I found a set of 2006 R6S forks on ebay that I bought. I just need to machine the spacers, and I should have them within a week with this whole thing solved I hope......and then I will have R6 forks
