I got a replacement fan for $40 !!! :cheer: Hooray! Went to a scrap and apparently a crashed Kawasaki had the exact same motor, with a slightly different spare part no. The mounting were different but I simply mounted with my existing one. The blades were more or less the same but I also switched it with my previous one. Tested it and it works fine! Seems to be slightly louder but not sure.
Changing the fan though was a b!tch! You have to remove the air intake, the battery, the battery box and the connector is hidden underneath a pile of cables. It really couldn't have been at more impractical spot.
Take care of your fans ppl, it is a lot of trouble to change it.
Finalimpact: There are no other labels on the fan itself.
The fan is sealed, cannot pry open. Tried roughly but bended the metal instead.
Motogiro: Do you still want the motor?
