Front tail light broken
krim
Montreal
Front turn signal light broken
I live and work in the city in Montreal and an idiot back up on my baby and broke the bottom of the light's bracket .
the top part is still attached to the fairing
what can i do to fix it?
Temporary fix was to attached it with a tie rap.
I bought some Rizoma and i want to put them on .
i found this in Canadian tire.
i doubt it will do the job
So is the boss where that bracket mounts torn off? The photo doesn't tell the whole story.
1) If the metal is broke. Drill holes and zip tie it together and then order a new one or go to fleebay and find a motorcycle salvage, parts yard, or parts salvage, or NEW from yamaha.
2) If the fairing boss is broke you're gonna need some fiber glass, fiber glass resin, and then you can use that bottle of hardener you've got pictured. It can be repaired but it will take a little effort and creativity.
3) Consider Installing some after market side lights on the fairing.
Can you take a better picture of the damaged area?
