Being obsessive compulsive, I decided to write to Yamaha about this:
(ChevyFazer, I made you my 'mechanic' for the purposes of the correspondence)
Good Morning,
I have a 2005 Yamaha FZ6 in mint condition with 28000kms on it. (NOT one of the batch with the faulty TPS)
I have just been speaking with a mechanic on the topic of how much fuel is left in the tank before I refill.
I usually run the tank fairly low between fuel stops (320kms+ @ 18L of the 19.4L tank) and the mechanic said this was bad for the fuel pump, as the fuel pump needs enough fuel in the system to cool the pump down.
My question to you is how accurate this information is? Is it bad to use the majority of the fuel in the fuel tank?
At the moment, I'm doing approximately 120kms a day, to and from work, so I am refilling every 2 and half days.
I use 98 RON fuel, always, in an effort to keep things clean, and run Motul 7100 synthetic oil.
Please advise if I am harming or shortening the life of the fuel pump with my refuelling strategy.
Sincerely,
Rick
And this is their response:
Dear Rick,
You can continue to maintain your current refuelling method it should not damage the fuel pump. The major factors for fuel pump damage would be contaminated fuel, foreign particles or concentrated additives etc.
Regards,
Duilio Pianca
Customer Relations Department
Yamaha Motor Australia
I understand the concept behind keeping enough fuel in there, to cool the pump, and absolutely, running the tank dry is a bad, bad idea - but the above would seem to support my refuelling strategy.
One of the reasons I run my tank fairly empty, is because, whilst we all talk about the crud in the bottom of the tank, isn't it a better idea to expel that crud incrementally, rather than let it build up? (and possibly one day run out and SERIOUSLY clog the fuel system?
I use the same logic(?) for my cars.
Just my theory, and one that seems to have served me ok, thus far.
The question as the integrity of the fuel pump seems to have been addressed, by the above, so I would say that if anything WERE to happen to the pump, as a result of my refuelling strategy, I can now refer to the above and hopefully Yamaha would come to the party.
Hopefully.
Cheers,
Rick
