TJP
2004 FZ6 11,500 miles
Laid bike down 1.5 months ago but only cosmetic damage.
Changed oil the first time last weekend. Drained oil in evening then couldn't get filter off so waited til morning then had to flatten one side of filter to get channel locks on it to remove...thanks last owner! :Flip:
Anyway...I added about 2.5 qts then started bike like usual for a couple minutes then add the other .5 qt for a total of 3 qts.
Oil level light starts flashing 10 times indicating faulty sensor which was fine up until the night before.
Everything is plugged in and sensor is snug in pan. Tried unplugging sensor but light just flashed even with key in "on" position.
Really don't want to pay over $100 for new sensor. Don't want to drain oil again to check sensor if don't have to because apartment manager nazi hates when I work on the bike.
Questions:
Is it possible sensor is stuck due to motorcycle sitting overnight without oil? Woulda thought it would have unstuck after 5 days of riding though.
If I cut the wires to the sensor and leave them unconnected or cut them then connect the two together (depending on if it's a naturally closed or open circuit), can I fool the ECM into thinking all is fine so the light will go off? Don't need this "feature" anyway.
Or am I just screwed out of $100 now??
Sorry so long...just thought all this info may be important.
Thanks in advance!!
Questions:
Thanks in advance!!
