Bi Xenon Projectors
Rover da Niga
Chile
Hi everyone
first of all please excuse my english :(
I want to shared with you guys my headlight mods, i installed a morimoto mini h1 kit, bi xenon projectors. And i installed too a couple of white led in pod lights
first my olds pod light (yellow), and compared with the new leds (white)
the led light are a lot more bright than the old yellows, but you all know that the cameras adjust the focus and light when you shoot, but are a lot brighter
here you can see against the wall, yellows first and then whites
and now come the HID :)
first my old plug and play hid kit
low beam
low + high beam
well, not bad ;) anyway a better light than the old old halogen stock
but.....
now THE PROJECTORS :o
low beam (just one projector turned on)
low beam (two projectors turned on)
and high beam (2 projectors)
from a little steps behind
low beam
high beam
and how they look
before
after
and some more pics compared with an standar FZ6 of a friend of mine
here some other pics of the installation
https://picasaweb.google.com/pattrask/Proyectores
and finally how they work
[ame=http://www.youtube.com/watch?v=RGQ__-gBC9s]Yamaha FZ6 S2 - Morimoto Mini H1 Bi Xenon Projector (V3) - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=yf56tfibufw]Yamaha FZ6 S2 - Morimoto Mini H1 Bi Xenon Projector (V1) - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=_41_hOxht2s]Yamaha FZ6 S2 - Morimoto Mini H1 Bi Xenon Projector (V2) - YouTube[/ame]
when you switch to high beam in the video you can "see" the movement of the curtain, but in real life you can't see that, is more quick, only the camera catch the effect
and then, when i turn both proyectors on, first you can see more bright, but then the camera adjust the light, but with 2 on are more light output, but in the video you can't see the effect :(
well that's all, sorry for the long post
bye
Fantastic! Amazing how much more projectors put out vs HIDs on this bike.
By the way, LOVE the color and decals on your bike!
thanks so much guys for the nice words and the welcome :)
really love the projectors, i think they look better than standar reflector
but more important, the quality of the light and the beam are a HUGE improvement from the standar halogens, and include from the plug and play hid kit
in fact the bike improve from just one "headligh" for low beam, and one for high beam, to TWO for low and TWO for HIGH, so really put a lot of light down on the road :)
Well done! I did the FX35 Infinity Bi-xenon retrofit into my FZ6 a couple years back...it is amazing compared to stock, morimotos are great performers for their tiny size.
Also, I LOVE the color scheme of your bike...that is factory, correct? Wish we had that here.
yes sir, color scheme is factory :) :) love it too xD
that was the last, before yamaha discontinue the model :(
my first idea was install a 3in projector, but need to much work to retrofit a projector from a car, so it was much better and easy to use the 2.5in morimoto, because you install it in the same reflector hehe, and need less work :D
do you know if there are too much difference between the morimoto and the FX35??, in light output quality??
thanks
Is this street legal and is it hard to do? Reason I ask on street legal is because with any car it is actually illegal to switch out the stock lighting for anything else other than halogen if it came with that or HID if it came with that. Didn't find this out until very recently.
I definately would be interested in doing this myself. One of my headlight covers is cracked I assume I would need to replace that as well?
This is fantastic, wish I could do that to my Fazer...:rolleyes:
Which led pod lights did you use, do you have a link?
I have used some cheap ones from ebay before but the light was not bright enough although it was very white.
Now I installed a pair of Philips BlueVision 5W5 and they are very bright but still not white... have that yellowish hue that I don't like...
thanks
I actually know a lot about the Morimoto and the FX35 projector as I have been retrofitting them into car headlamps for years and have been testing them quite a lot. The FX35 Now has a replica projector called the FX-R ([url=http://www.theretrofitsource.com]The Retrofit Source online: headlight upgrades for all applications) [/URL]which performs about the same as the OEM FX35. The FX projector is about 10% wider with a brighter and taller highbeam in the center of the beam than Morimoto, otherwise they are pretty close. Both have that nice blue color and a sharp cutoff line on a wall.
THe FX-R is a bit more difficult to retrofit because you have to make aluminum mounting plates that replace the headlight reflectors, using the same black grommets that held the reflector and then the projector bolts to the mounting plate. Here is the write-up I made when I did this:
http://www.600riders.com/forum/fz6-mods/36737-ultimate-fz6-bi-xenon-hid-projector-retrofit-infinity-fx35.html
That looks great.
are you planning on painting the reflectors and shrouds black? or you like the stock look?
I had these projectors in my SV650S before i went naked bought a custom projector retrofitted streetfighter headlight.
Projectors is definetly the way to go, both for looks and light quality.
Thanks so much for your answer, i'm very clear now, and so sorry guys for post this so late :D
svzxr650 I left my headlight in stock color, I like the "chrome" look inside the housing :)
Here I have a couple of pics (low/high beam) in a back road, unfortunatly i forget to desactivate the flash of the camera.
My next mod will be a couple of auxiliary spot led lights, I hope in the next month :)
:thumbup:
thanks
hello friend!
so if i buy 3in projector would be better?they are selling some good HID projectors kits 3'' etc. will it fit into the headlight?
Jim - I have morimoto mini H1's in mine. these are 2.5". The fit is already tight with the shrouds using the mini gatling gund shrouds. Not saying it cannot be done with 3" projectors but I would think you should be prepared to shave off a bunch from the shroud to make it work. I am interested to hear how this goes and see photos. I bet the beam quality is excellent with the larger projectors. Thanks and good luch
REALLY REALLY thank you for the answer. :rockon:
See this link please: 2x 3.0" Motorcycle Bike HID BI-XENON Projectors Lens Kit Halo Angel Devil Eye AC | eBay
this kit i want to buy. The seller says that no shrouds need. So this will be ok?!what do you think?
dont know if i mention that i want to put them at FZ6 Fazer S2 '07.
Also i think that it is full kit, no buy any extra accessories i think.
Thank you very much friend!
i am thinking buying this kit which does not want shrouds extra as seller told me.
what do you think?will it fit?
2X 3 0" Motorcycle Bike HID Bi Xenon Projectors Lens Kit Halo Angel Devil Eye AC | eBay
i think it is dont want any extra accessories the kit to buy extra.
