Corsara
I bought my FZ6 recently, and I noticed it doesn't have marks for aligning the rear wheel. What's up with that?
the blocks that the axle goes into have either been put in upside down or the wrong way around, i wouldn't rely on the marks too much though
Corsara, I've got one of these chain adjustment tools (I just bought it over the winter) and I couldn't be happier with it. It takes all the guesswork out of aligning the chain and, consequently, the rear tire. Just pop it on the top of your rear sprocket and sight down the rod until it's parallel with the chain. Of course, you still need to get your chain slack correct, but that's easy once you get everything aligned. I can't recommend it enough. :thumbup:
Motion Pro - Chain Alignment Tool
+1 to the chain tool above.
Also, just as an FYI: You shouldn't use a torque wrench to remove bolts as it can, and will, destroy the calibration.
So let me see if I get this right: if the sprocket is perfectly aligned with the chain, that would imply that the whole rear tire is also perfectly aligned, yes?
It depends on the type of wrench. The ones that break on the inside are usually okay, as long as you don't keep cranking on it when it breaks. Most torque wrenches are locked to one direction. Meaning they only ratchet in the wrong direction. The ones with the switch are usually okay as long as the torque doesn't exceed the maximum rated torque. And you then count that as a torque cycle once the bolt is off.
Or look into some of StrongArm's bi-directional torque wrenches. They're fine either way. But if it pops then it's a torque cycle.
I generally don't use them to take bolts off though. That's what regular wrenches are for.
I will say generally...yes. That assumes that your sprockets are straight (aligned) correctly on the wheel, but I've yet to see anyone with that problem.
I think about it like this...the sprocket sits at a 90 degree angle to the axle. Because of this, the chain sits at the same 90 degree angle to the axle. So, based upon that, if your chain is aligned properly, then the rear wheel should be aligned properly.
But that's really over-complicating things...lol. My theory is, if the chain is aligned, then the rear wheel is aligned. :thumbup:
