sabretooth
Don't know if anyone else here has had this happen, but just thought I would share in case you have similar symptoms. I have an 04 FZ6 that now has over 11k miles. Never had issues with starting other than battery, but that was to be expected with a 6 yr old battery. So with new battery installed I figured I was good 2 go this season. Started right up and purred great for about 2 min. After that the bike would start missing. If you let it cool off you could ride it hard for a couple minutes again and then the misfire would start to creep in again. It would first show up at low RPM only under a load but eventually after time miss through the entire RPM range. No ECU codes... so really fun to track down. Plugs were original so I bought a set of 4 plugs and intalled... talk about a double-jointed monkey job! After doing that still had a miss, but I figured it was good I did that anyway since plugs were looking worn. I went through and pulled each plug cap one at a time to see which one was missing. When I would pull the cap off on cylinder #4 there was no change so I knew this was the offender. One thing I noticed, besides getting a HUGE shock, was that there were sparks jumping right out the side of the plug cap. I tested other caps and they would not do this. I went to order a cap from a dealer and they wanted $60.00 for one cap!!! So I went on ebay and got 2 coils with wires and 4 caps for $35 shipped to my door (would have cost over $430 for all that from dealer). When I got the parts I installed new cap and presto... problem fixed!!! Just wanted to share this since I took the old cap that was bad to a dealer and it tested as good! The resistance was fine, but the problem was the inner insulation was bad which they couldn't test for and there were no physical problems that could be seen with cap- cracks, etc. So even though you may think a cap is fine because it passes the resistance test that isn't always the case as I learned. But now all that is behind me- ran errands yesterday and ran great! Took to work for first time today even though it was 28 degrees... had to lay down the whole way since it was COLD on freeway! Happy riding to all and keep the rubber side down
Sent from my SCH-R880 using Tapatalk
