FIZZER6
The Angry Blue Mantis
I did this retrofit a couple years ago and decided to post it here for the good of this community as well. This is a very worth while modification! Even if you don't ride at night the flicker of HID projectors makes you more visible in daylight!
2006 Yamaha FZ6S
Projectors: Infinity FX35 Bi-xenon with RS 100% optically clear lenses
Ballasts: Denso 35Watt (OEM Lexus/Toyota)
Bulbs: Philips 85122+
Mounting plates: 1/8" sheet aluminum
Mounting bolts: #8/32, 2" stainless steel
Washers: #8/32 stainless with lock washers and flat washers
I'll let the pictures do the talking.
Cut a template out of cardboard cereal box first, then traced it to the aluminum sheet:
Made a second for the right headlight:
Cutting!
2006 Yamaha FZ6S
Cutting!
