Background:
Converted the bike to streetfighter and the original front running lights / turn signals are now hard-mounted to the new headlight brackets (no rubber piece to suspend them from impacts and vibration).
I cut original connectors out and replaced them with bullet connectors, but all wires are connected in the same order.. no color mixing.
Problem:
Ruinning light filament on the right side burned out after about 5 hours of use. I replaced it with a generic 7443 bulb. It burned out once again after about 5 hours. I then took the OEM bulb out of left side, put it in right side and put a new generic bulb in left side. Right side burned out once again after about 5 hours of use AND the left side now burned out as well. Blinker filaments are still working.. only running filaments burning out.
Question:
What do you think is causing this? Could it be the added shock and vibration from hard mounting OEM signals to headlight brackets?
Or do I have a short in the system? How would you troubleshoot this?
Problem:
Question:
