1-2 gear jerk when rolling on the throttle
pocket
Galveston
Hi everyone, I'm new to this forum and a new owner of a 2007 Fz6 with about 11,000 miles on it..I've been riding the bike for about a week. I'm not a newb to riding motorcycles, but I'm not that seasoned either.
The problem: Im in first gear->roll off the throttle->pull in the clutch-> shift to 2nd->relase the clutch-> and when I roll on the throttle, it jerks, not a smooth throttle response.
I have checked the chain-> it has about 1 3/4 in. of slack--this is measured with the bike on the side stand.
I have also experimented with shifting at different rpms, at 2,000 and at 5,000. When I shift at 5,000, the throttle response is a little smoother, but still has a jerk.
My last motorcycle did not have this problem, but it didn't have a high compression motor either. Can anyone help me out? Thanks
Try this:
1. Preload the shifter
2. *Slightly* roll off the throttle
3. Simultaneously pull the clutch and upshift
4. Release the clutch and roll back on the throttle
This is the trick to a smooth shift...
Preloading the shifter makes a HUGE difference...
Remove step 3 and the first half of step 4 and you've got clutch less up shifting:BLAA: I wouldn't recommend it from 1 to 2 though.
Your suggestion only applies when you're on the throttle firmly - otherwise, I agree entirely.
I use clutchless upshifts on the highway when I'm hitting the throttle hard, and I never use them through the neutral gate (1 to 2 upshift).
