ginster vr6
I keep hearing talk about how it should be removed when running no cat but I can't seem to find what needs to be disconnected to blocked off. Can anyone help me?
I'm trying to eliminate the popping on decel that has become rather annoying. The AIS intake is the hose connect on the front ride side of the airbox correct?
I'm going to temporarily plug my AIS today in prep for a dyno tune, can anyone confirm if this is the hose from the airbox I need to plug? Hoping it is because then I don't need to start pulling things apart. Cheers.
(have read the R6 removal instructions but think the airbox and a few other things are a bit different)
I'm led to believe the results will be more accurate with it blocked though.....thoughts?
Anyone? Just trying to save myself some unnecessary wrench time.
On a side note , i LOVE my de-cel popping.. Makes the animal sound even nastier :BLAA:
You can dyno a bike without blocking the AIS.
Yes, of course you can dyno the bike without blocking the AIS but you cannot have accurate numbers from a wideband lamda so you cannot adjust the A/F ratio on a dyno.
Before i've blocked the AIS i've showed 18/1 A/F ratio (!!!) and i could find out why! I spend almost two hours searching for an unexcisted hall to my exhaust!
I thought that there was a small hall somewhere on my exhaust and the air from this hall was affecting the lamda sensor!
After i've blocked the AIS i saw a dissent 14.3/1
