HGFireHazard
I decided that I wanted to do something new to the bike and I do a good amount of riding at night, so I thought a fun project to undertake would be to retrofit a HID kit in. After some browsing and recommendations on the web I went through The Retrofit Source and picked up their Morimoto Bi-Xenon kit. $295 seemed like a relatively inexpensive amount of money so I jumped on it.
I made some great progress a couple days ago. The Morimoto projectors are designed with the back threaded and the kit comes with mounting hardware to work with halogen housings, but unfortunately that isn't good news for us. I attempted to see if this hardware would work, but our housings are a bit too small for the projector to seat correctly.
I also went a step further and cut reliefs into the halogen housings (I figured why not, I won't be needing them after this) to see if the supplied mounting hardware would work. Again, the results were less than favorable. One side, when fully tightened, wasn't making contact with the back of the halogen housing so the projector flopped around a bit. The other side I was able to tighten up pretty good, so I wouldn't rule out that you could in some fashion make that design work, but I already bought the aluminum so I said screw it.
I also strayed a bit from the previous designs and decided to use the brackets on the back of the halogen housing bolted to the aluminum plate that I cut out. I thought it would be easier to do this than cut accurate reliefs for the stock adjuster blocks.
I sprayed the brackets yesterday, and I still have to test the kit, set the projectors level, drill the projector mounting holes, wire the high beam shutters, and adjust some wiring lengths.
Also, for anyone else interested in this kit, take note that if you decide to make brackets, you will need to use precision on the hole you cut for the projector. Unlike the FX35's, the smaller size of these comes with a mounting price. The mounting holes on the projector are relatively close to where the hole will need to be for the projector itself, and you can't just go extra big, otherwise you won't have any material to screw the projector into.
I have some pictures to give you guys a better idea of all I'm talking about.
