I got my springs last Wednesday and just got them installed today. Delivery took almost 3 weeks! I was going to work on them last weekend but got hooked into other stuff and then we got power outages here in NH and that put a damper on things but last night power was restored so today, I went to work on it.
I bought a steering head paddock stand to make the job easy for me -- I don't have a center stand and wanted one of these anyway. Dealer quoted me $140 for the installation and the stand was $136 so there goes that money -- but I come out with a stand
I think the install was pretty straight forward -- using SANGER_A2's instructions from his site. Things were a little complicated for me because I have FZ1 bars and had to remove them to get at the fork caps.
I used 15/16" socket to get the fork caps off -- I think that was the only new tool for me. I've removed front wheel, brakes, etc. before so I had all that already.
One thing interesting was that when I poured out the old oil, it was kind of milky white. Is that bad? Maybe the oil deteriorated? the new fork oil is kind of goldish.
Another interesting thing was that the manual says fork oil should be 134.0 mm from the top of the tube while the Hyper Pro instructions say 200.0 mm. You get a liter of 15wt fork oil so I have about 250ml left.
I had to hold the fork between my legs to use two hands to get the fork cap back on because the spacer was poking out through the top -- even at no compression. Cutting bigger spacers and using them might present a bit of a challenge to install.
I have not installed the rear spring yet.
I kept my 10mm forks through the triple I had before the Hyper Pro springs. I took the bike out for a quick run on some highways and exit ramps and it felt good. I only went about 20 miles so I'll wait to post any impressions. But so far, some frost heaves seem better. I wonder if the front was raised. Maybe I need to bump up the rear preload (currently at 5 for me). As others note, front end dive is reduced and damping feels better.
I'm going to wait on installing the rear spring until I adjust the rear preload and see how things go. Maybe by then, I'll get up the nerve to try to remove that rear shock. For now, the bike feels funner -- if that makes any sense.
It's hard to tell what's really fun because aside from the fork springs and heavier oil, I rotated my FZ1 bars back for more of a clip-on feel, upgraded to EBC HH pads on the front, swapped out my rear tire for a used BT-016.
Dennis
