Heated Grips - Oxford Heaterz
I was advised by a couple of people to go for the "old fashioned" controller with a rotary dial... Reasons
Set rotary dial then push on/off, next time you use them they are already set.
Fine control over power, not fixed power levels
Even with a new battery and good charging circuit the low voltage cut off can kick in when stopped at lights etc, then you have to press the button to get back to the same power level.
Electronics draw current even when off so you still need to wire through a relay switched from ignition to help protect the battery when parked up.
I have the same ones, except mine has the dial controller instead of the electronic one.
My first dial stopped working after the first year (heavy rain or snow messed up electronics), but my second one is going strong. If this one goes, I will just install an on/off switch. That's all you need really.
Just to let you know, you will probably have to cut-off your old grips. I tried to slip them off, but the glue was too strong. Ended up using a utility knife to cut them off.
I LOVE my oxford heated grips, and if by far one of the best mods I have done. Even for those cool summer nights/early mornings, it is so nice to turn on the heat!
Thank you for the feedback on these. I know that I will have to cut my existing grips off (unless I can 'blow' them off with my air compressor). As for the on/ off switch, I am not sure quite where I would install it, at least not how I am thinking about wiring them (wiring isn't going thru any plastic).
Hopefully, with 5 power settings, I will be able to find a setting that fits my needs. Of course anything is better than nothing at this point.
If an effort to extend my riding season, I'm looking to install some heated grips on my 2005 FZ6. I'm curious as to whether anyone has experience with the Oxford Heaterz grips...
TwistedThrottle.com : Oxford Heaterz Heated Motorcycle Handlebar Grips for 7/8-inch Diameter Handlebars, 4.9" long - OXF.26.0695
My husband put them on his XJR 1300 for winter - push button not rotary dial - absolutely loves them. Weren't too difficult to install and they do keep his hands warm - 2'C was about the coldest we got to in the winter mornings. They have 3 or 4 heat settings.
I have symtec grip heaters. If you search around, you can find them for around $30-40. Had them on my VFR, too, work great. You take off the stock grips, install these, then reinstall the stock grips (use hairspray as glue). Very warm, much cheaper then the oxfords. Also, you'll find ATV ones and motorcycle ones, i had ATV ones on the VFR and now have motorcycle ones on teh FZ6, the ATV ones seem to be warmer.
I used to have these exact heated grips, with a set of Wind deflectors (hand guards), as well....
The heated grips rock! They get toasty warm, and make winter riding much more bearable....
Apparently the "Sportz" grips are even better, with raised push button controls...which are apparently a lot easier to use when wearing gloves....my only gripe with this particular model...the controls were hard to use with winter gloves on.
:thumbup:
:thumbup:
I too have the oxford Hot grips, and I agree the only (minor) gripe is that the controller can be difficult to work with winter gloves on, especially on the move. The grips themselves are great, ideal for commuting, If it's a little bit chilly just turn on the heaters :thumbup:
I was told by a shop once that they work best with "gel" winter gloves (which I don't have), but this could have been a sales ploy :rolleyes:.
i don't know how cold it gets for you but you should also look into handguards. i have a set of powermadd's on mine and they make a huge difference. i've had some cold mornings so far and my hands have been fine. if they get too cold i can just put on my winter gloves.
Same brand that i have....must agree, they make a big difference, especially in terms of wind blast, on the outside of gloves...
:thumbup:
