whats your air filter preference and why? :thumbup:
If you combine it with a PC or Rapidbike you should get some gains.
On a stock bike it's not really worth it.
If your stock is worn and you need to replace, you could get a K&N, pipercross, ... But you might as well get another stock one.
Ps: 5hp on 95hp ... that's 100hp![]()
I changed to a K&N, opened the airbox and Dyno'd the bike. Saw 4 HP difference at the rear wheel. Also keep in mind that most of us that are doing this have a different exhaust.
If I didn't have other mods I would stick with the OEM filter and keep the airbox stock.
Stock. It's fine and filters good. .5hp on a 600cc bike doesn't matter that much to me.
Did you dyno the same day with about the same temp, before and after?
Did you have a power commander to adjust things, or was it just dynoing to see the power gain with no adjustments from yourself?Yes. Same day...
Just trying to convince myself it's not worth splashing out hundreds for a power commander if the stock FI adjusts itself. I have Scorpion cans, the airbox mod and a decat pipe. The bike seems to run fine with it, but I'll be replacing the stock filter with a K&N when the time is due and hoping it won't need dynoing etc to run fine.lol are you just looking to disprove his figure to convince yourself its not worth it?
