mpa4712
Hello,
My 2nd mod to the bike, FZ1 bars. I also did the bd43 light mod and some flush mounts.
Anywho, I did a lot of research on the board before I made the purchase. However, I wasn't able to find any images of the angular difference in the pull back. So, I thought I'd post some pictures I took of the difference for those who are on the wall:
Here is a look from directly over the two. At first glance, you may think there isn't much difference here:
Head on, we can see the difference in height of the bars. The FZ1 bars are pretty flat. There may only be a SLIGHT decline in them, MAYBE 1/8 in. over 8-9 inches or so.
Lastly, we have the bars say on top of each other. FZ6 bars on top. I lined up the middle shanks of the bars and the mounting rings perfectly. Here, we see that the FZ6 bars are pulled back quite a bit more, and are rather sucky.
I'll post more pictures later of my clearances. I am able to do a full 180 turn lock without touching the tank. I'd say I have about 1/4 in. clearance on both sides, pretty decent. I found that with the bars being at a more aggressive angle, the brake and clutch levers also needed to be turned forward quite a bit more. I ended up rotating them both forward about 1/4 in. as well. Now when I sit on the bike, my hand go over the grips, and extending my fingers out straight puts me over the levers.
For those wondering about the little dowels that come off the controls and into a small hole on the stock bar, you can safely remove those. I cut off all but maybe 1/16 in. I put some electrical tape around where each control would like up for some added grip. The screws (two per side) will hold them plenty tight.
I saw a few other posts about people having to loosen the bolt holding the brake line on near the handles. I can confirm this as well, just gave it a little nudge, just enough to turn the line a bit. The problem is that the line will 'sit' on top of the tree a bit, and won't allow you to roll your brake level forward. Very easy to just loosen it, give it a little adjustment, then tighten it pack down.
Overall, pretty easy mod. If anyone has any questions please let me know.
Thanks,
Mark A.
Thanks,
Mark A.
