Help
kdog209
New Jersey, USA
My fizz won't start all the sudden. When I hit the start switch it just makes a loud noise like a nasty door buzzer. Road her all day, engine temp was around 211F at the time and filled up the gas tank a few hours ago. What's goin on? thanx.
No codes, it was the battery. I push started it, drove it around for 10 minutes, turned it off and started it again no problem. I drove around all day with the high beams on. Didn't know this could drain the batt. I left it on idle for a while a couple times today too. Thanks guys.
Good to hear the problem is fixed!!!
Perhaps you should consider to get a pulse maintenance charger, - will keep your battery fit for fight.
Only if you idle a lot or keep the revs below 5k.
I used to use my high beam all day and never had a problem, but I turned it off at stopsigns/lights and kept the revs high.
