Question on the FAZR6 FE
BranNwebster
The UNO Master
Webster Texas
Question on the FAZR6 FE.
Do you use your old lights? If so is it easy install? will I need to run to Autozone for any extra things?
And for Texas riders what do you do with the inspection sticker?
You use the stock turn signals and plate light. I guess if you wanted to you could use other lights. It is relatively easy to install and a step by step instruction guide w/pictures is included. I'm pretty sure I didn't need any other supplies, maybe an extra zip tie. As for the inspection sticker I don't know how texas does it, but when I was NC we could put them on our fork tubes. Hope that helps.
FE install is easy and you wont need extra parts. although you will have some left over when you finish up( but don't you always?)
Use the stock signals, the FE is made for them. I was going to do aftermarket ones but after putting the stock ones back on they don't look so bad being brought forward and in. If you feel you really need to go aftermarket, they sell spacers to fit the aftermarket signals in.YAMAHA FZ6 2003 - 2005, TURN SIGNAL ADAPTERS* *FZ6 2003 - 2005* *YAMAHA* *RAD TOYS MOTORSPORTS
Good luck!
When I first purchased my FZ6, the guy at the inspection place offered to place it on the swingarm. Actually, he offered to place it anywhere on the bike. It must be visible, he explained, but not necessarily by the plate. Apperantly he has odd requests from the custom chopper/harley guys.
I don't have the FE, so I just left it under the plate.
