Ok, have finally got mobile enough to drag my bike out and take some more conclusive photo's of the damage.
Here's the list of items that are damaged.
1. Handlebar bent at 45 degree's on left side.
2. Left Bar end mirror trashed.
3. Oxford Heated Grip controller...trashed.
4. Instrument panel mount cracked.
5. Bottom of left fork leg, scraped....minimal.
6. Left engine cover scraped.....will need replacing.
7. Left Crash Slider well scraped, but not bent.
8. Left Rearset bent in, shifter rod bent against frame, left footpeg, bent up & back........
9. Rear subframe appears to be twisted.....
10. My ego!
Here's some photo's.....In the first photo, you can see how & where the bars bent. The Bar's also moved in the clamps during the impact, got pushed about 15 degree's up and around. Can also see trashed mirror & heated grip controller....can also see that Pazzo Lever is unscathed!
In the second photo, you can see the verey minimal scraping on the bottom of my left fork leg.....if i had my fork sliders, which are still on back order, this would of been avoided.
The third photo shows what the bars look like fromn the front.
This photo shows the rear end of the bike, it is pretty easy to see, all is not well, with the subframe, at the very least......weird thing is, there is not one single scratch on anything on the rear of the bike!!!!
In this last photo, you can see how the Valtermoto rearset is pushed in towards the frame, gear shift rod is bent against the frame.
am well on my way to putting together an evil plan to rebuild the bike to it's former glory, and maybe, even a little bit better.....at least it has "character" now.......Bloody 4WD!
A couple more photo's to come.
:thumbup:
10. My ego!
:thumbup:
