S
stevew
has anyone fitted an aftermarket exhaust, Scorpion, or similar? Is it a simple swap or are there complications..?
(complications? I sound like a Doctor!)
I plan on purchasing a set of Two Brothers M2 VALE Carbon pipes at the end of June (as long as my bonus comes thru!!) from Bayside Performance in Vancouver.
FZ6 Baffle-ectomy
Just a note regarding FZ6 exhausts. For those who like the factory look, like I do, I thought I’d share a possible option with you. I saw a post two days ago regarding stock muffler modifications and decided to perform the operation myself as well. I am not beyond my break-in miles yet (328 as of now), so I have not yet experienced the complete potential of the bike and would not notice a loss or gain in power from this modification.
My whole purpose was not for power gain. I just couldn’t stand the fact that this bike sounded like a 600cc Singer sewing machine and I too liked the factory look a lot! I don’t like the fact that the aftermarket pipes stick so far out and if I wanted a more powerful bike, I would have just got the R6. So with the whole point being that an FZ6 is just an FZ6, I chose the path to a louder exhaust only.
I did design a strait pipe set up first since the CAT acts like a small muffler and the exhaust system has so many bends, the noise volume would not have been too much. That idea was shelved when I figured how much work it would have taken to fabricate mounting brackets for the system and the exhaust cover (again, factory look).
The operation took place on the bottom of the muffler to avoid all the mounting tabs on the top. I used a rotary (Dremel) tool and stone blades (29) to make a thin cut (makes easier welding). I cut a rectangle approximately 2/3 of the bottom, cutting through one of the baffles and around two of the spot welds. I cut squares around each of the spot welds to pull off the outer skin and left the inner perforated skin for the blow torch.
I was lucky enough the have a friend who’s back yard looks like the cable show Junk Yard Wars. He has anything and everything to make ANYTHING. So the blow torch and TIG welding were done at his place. This brought the cost down considerably.
The muffler is designed just like a car muffler with three chambers and two baffles. It reminded me of the inside of a BOSE subwoofer. The exhaust enters chamber #1 and is transferred to chamber #3 and then back to the middle chamber #2 and then out your twin exhaust tubes.
We started by using the cutting torch to remove the perforated inner skin where I had made my cuts and then cut out the first baffle and tubes and then the second baffle and tubes so that it was one big empty muffler can. Once that was done he cannibalized the parts I had cut around to fill in the wholes on the outer skin and weld the cut pieces back in. we used that same outer skin to seal up the muffler. This was about a 90 minute weld job. That fact alone makes it expensive, but still cheaper than a set of pipes. We reused the original muffler skin, so it looks a bit factory with a surgery scar.
The completed job looks good and the bike has a unique sound. It is not nearly as loud as after market pipes. The sound is a cross between a muzzy, a two-stroke bike and an F1 car. I know that statement sounds crazy, but the sound is unique. And the sound is very cool!! It works well for Orange County beach riders since Newport Beach police like to give a lot of tickets for loud exhausts.
I have pictures in my TREO phone, but can’t get them to download into my computer, so if you want pictures, I’ll have to send them via cell phone for now.
As a note, my friend is a certified welder and on the side makes patented metal work and fabrication for off road trucks, buggies and bikes. This means he will do the mod for anybody interested, but for approximately $150.00 (you bring him the muffler). If you live in the So. Cal. area, let me know. You can even look at and hear my bike in person to see if you like it.
Bike10
Hey Boneman I read the site that you put down and are they talking about just drilling one small hole right down each pipe? Not though the outer casing o fthe muffler right. ( That would be dumb ) How deep? I just don't have the money right now for a set of cans and I don't want to screw anything up. I thought that the discription was alittle vague , or it might just be me.
Woooo!!!!
Congrats man. That will be fun.
You could hang out in the garage, burn some patcholli, eat some organic soy nuts, and wrench.
