youngGun
By now you all know my poor FZ6 has been in the shop, due to a knocking noise coming from the engine. Well after 9 weeks and almost 4 thousand dollars worth of parts and labor...its Finished. if you dont know the story ill fill you in............I took the bike to my local Yami dealer to have the noise checked out, bike was still under factory warranty (by just 10 days)...the shop found broke clutch plates, and abnormal wear patterns on one shift fork, as well as first and second gear. They decided that they would replace those parts and put a new clutch basket in while they had it apart........5 weeks after dropping it off i get a call that i can pick it up at noon the next day, i show up early to be there for the first hit of the starter.........My baby roars to life, only to have the same freeking knock :spank:.......they tell me that they will tear the entire engine down to the bear block witch they did, and found NO problems whatsoever
.....they went ahead and replaced: pistons rings, wrist pins, rod bearings, rods, and pistons.......................................................................got a call today, motor is done, in the frame and about to be fired up, and ridden to seat the new parts.........a couple hours later i get another call.....bike runs better than new BUT......................................................................................
............................IT STILL KNOCKS!!!!!!!!!!:spank::spank::spank:
my dad is picking it up tomorrow and hauling it to me at school....the yami shop is calling a yamaha specialist tech to look at it in a few weeks, but till then i will ride it like i stole it, i have a two year extended warranty so no worries.......just wanted to share my nightmare!
