fazer.rider
Super Member
hi, i installed this yuasa smartshot 900 charger. it's rated for 12v at 900mA. the harness is a SAE outlet. is it safe to run a GPS to it? i don't wanna burn a fuse or anything. thanks =)
yep. totally safe. your tender lead should have anywhere from a 3A-7.5A inline fuse. The GPS will likely only use about 1A to run.
thanks for the info. here's the thing. the manual doesn't say anything about what fuse it uses. just says "output: 12v @ 900mA." if it's 900mA why would the fuse be 3A or more?
sry for the dump question. i don't know much about these kinds of electrical stuff.
