Puig it is in matt black.
I like the blinkers a lot, great find. Where did you order from? Thanks for sharing the part numbers.New goodies came from the EU....
They are made by yamaha, the front have white DRL and turn The rear, turn, run, brake.
They seem pretty bright both front and rear but have not been installed yet. The color plates swap out so they will be black and not silver. They come with load ballasts, but with an electronic flasher, there is no need for them. They also have rubber cushion at the mount and can move so as not to shear off but certainly not as limber as the stock oem mount.
YME-FLB2F-00-00
YME-FLB2R-00-00
Blinkers front and rear
View attachment 67602View attachment 67603View attachment 67604
Front operation:
https://youtu.be/tcJ8rI-mPk4
Rear:
https://youtu.be/eEJkZ8UIWBE
This needs powder coated then I can install..
Rear (not my bike)...
Marcelo
Sent from my XT1650 using Tapatalk
Those signals are awesome. So crazy how difficult they are to find in the U.S.
Still looking for a viable option.
I like them, I just can't believe how expensive they are. It's on my list, just can't justify it now. I love the DRL feature and the combined brake/run/turn for the rear.FWIW I called two local Yam'r dealers and they both said they can not cross international boundries. So don't go looking for a dealer to do it.
The place I ordered from gave me 20Eur off the combined order (moto_outlet_shop) so I went w them. Packaging was top notch and it was here in like 7 days. I would buy from them again.
I'll post up the rear when done and get it outside!
Thanks, yes, ordered both the tear drop and wiring adapters from an outfit called Planet Bolts on flea bay. I plan on cutting some of that extra wire and butt splicing in the wiring adapters (with heat shrink), so that should allow feeding the wiring through the tear drops.
Thanks again!
Sent from my iPhone using Tapatalk Pro
PM said:Where did you get that 48t sprocket?
I got these signals front and rear too. They are great.Things to do when its snowing.....
Installed new lights in fairing.... And yes, that is an FZ6 wiring harness (and battery) powering those lights! I'll work on the aim too!
Forks get fresh oil every two years and the front tire has no meat on the sides. Could be used for 10k in the straights tho!
To do list includes brake bleeding and radiator flush. As well as cleaning. So much bug juice dried in the radiator core.
[MENTION=18050]Marcelor73[/MENTION] lights in operation...
