Astennu
Sometimes the return spring is a little undersized and doesn't always push the shield back up when you turn off the high beam. (The solenoid pulls it down, the spring pushes it back up). Also possible the mechanism is binding ever so slightly. If the connection is bad, it should default to the low beam (no power). That was a common problem with people using the Morimoto Mini H1 over at HIDPlanet. The solution was to just stretch out the spring a little bit before assembly, and maybe hit the mechanism with a little high-temp lube of some sort.
Thanks for the info. No power = low beam. But it gets stuck in high.
I will check the connectors first but if that does not help it seems there is not other way then taking everything apart again
In that case i think i will RMA the whole unit to get a new one. Dont want any problems in the future. Its just to much work.
