- Joined
- Jan 13, 2008
- Messages
- 1,948
- Reaction score
- 45
- Points
- 0
- Location
- Festus, MO, USA
Re: Wiring complete
Pretty big project isn't it?
if you haven't done anything about this yet I would try getting a headlight restoration kit, I got one from walmart for about 15 bucks for my Subaru, it had a small super fine abrasive pad that I used to remove the yellowing and small scratches/chips from the lens essentially making the whole lens cloudy, then there was a polish that you put over the cloudy lens that dries clear, it worked great and the lens looked brand new. Only thing is I'm not sure if my lens was glass or plastic, I don't have the car anymore or I'd check, but it seems like it was plastic. That abrasive pad might be enough to remove your scratches though, I'd just check in the instructions and make sure it's safe for plastic lenses.
OKAY...that didn't work too well...it broke in half...lol
NOW...how do I 'glue' it back together? Open to suggestions...Solder the two pieces back?
Thanks! I'll go with JB Weld. If I just solder it, I think it'll probably break when I try to put it back in the holder...and take the chance that it might melt?
Hopefully it'll be strong enough and works out. Then I could swap the both shaders around.
NOW...how do I 'glue' it back together? Open to suggestions...Solder the two pieces back? JBWeld the thing back?
I had the same problem with one of mine staying on high.It turns out that water had got into the connector.I sprayed WD40 in ALL the connections and didn't have the problem again unless I rode in very heavy rain.
