Turn Signal and Rear Reflector Mounts
Ruggybuggy
Northern Ontario, Canada
I need a couple of turn signal, left or right, front or back it doesn't matter as long as it has the plastic insert that holds it onto the bike. I don't even care if the lens is cracked. Also need both rear reflector mounts and it doesn't matter if the reflectors are on them. Trying to fix a boo boo after installing my LED turn signals. Should always measure twice and cut once. :rolleyes:
Talking about stock rear
Fender and front turn signals ? With clips if so I have em :) I can send pics if thats what you need
If you only need the base of the indicators (to mount the threaded shaft of the LED indicators to the big OEM hole), why don't you just get the adapter plates thatgoin there?? (just guessing that it's what you are trying to do :) don't shoot me :D)
Grtz,
Degake
Sent from my New iPad using Tapatalk HD
