Hello my fellow two-wheelers.
I have finally ridden my bike after the Scorpion exhaust/PC3 install. (it's been a tad wet in Adelaide, for the past week!)
Firstly, riding up the road, the bike juddered a bit before smoothing out, and it made me wonder about the ECU recalibration. (since I removed the battery lead for a while)
As I understand it, after being disconnected, the ECU apparently recalibrates itself.
Now, as I have the PC3, loaded with the default map for my pipes, I was wondering if this could upset the ECU calibration, or even negate it?
If the ECU is calibrating based on a stock bike, and the PC3, knowing this, is calibrated to enhance stock - if you load a map into the PC3, the ECU will be trying to calibrate based on those modified values.
Should I have ridden the bike with the 'stock' PC3 map, let the ECU do it's thing, and THEN load the map specific to the exhausts.
Or, like usual, I'm probably reading too much into it. (one working the spark, one working the fuel management - and thus they can calibrate independently of each other.)
Thanks for reading my ramblings, but if anybody has any info or opinions, I'm all ears!
Cheers,
Rick
P.S. After work, tomorrow morning, I'm planning a 400km trip - without having the bike dynoed, do you think it'll be ok with the PC3 map for my pipes, or should I get it dynoed to be sure? Thanks.
Cheers,
Rick
