DecepticonDon
I have told many people that my 05 fz6 is fast enough with exhaust/air filter pcIII, but my father is an old school hot-rodder. I told him that he polluted my young mind with chevy small block horsepower. I am looking into the je piston 637 kit because I believe in the power of a sleeper FZ6. Not many sportbikers know what it is, nor do many R6 owners know of the shared engine block. Rider skill is an important factor, as many sportbikers I've talked with are "grip twisters" i.e. that is their only skill, they don't know squat about clutch control, or things like where their peak HP is in the revs. Wringing the FZ's neck, I ran 7.242 in the 1/8, but there is not a 1/4 locally. With the 46t sidewinder tri-metal sprocket installed and 520 chain, I'm going back. Although the new r6 has shorter stroke larger diameter cylinder, the block is the same. It is plausible that someone could buy a salvage 06-08 r6 engine, bore and replate the fz eng, swap the head and other essentials, keep the stock injection, the clutch i believe will work, the clutch pull lever goes into the bottom on the case on an r6, top on the FZ6, but the orientation should not matter since the shaft is poking out the center of the clutch.
