manas12
Hey All,
I just finished installing the scorpion slip-ons on my fz6. Everything went well on the install, but when I turned on the engine to check for any leaks in the pipe, there seems to be a small amount of air leaking where the cat-pipe meets the mid-pipe. I made sure I tightened that clamp real good, but there is still a small amount of air leaking and a bit of water also leaking out.
I used the spanner that came in the bike's toolkit and maybe that is why I cannot get it real tight because that area is hard to reach and apply torque. What kind of tool would you guys recommend using to make sure that that clamp does not leak air?
I did not notice any problems with the exhaust note as such and the leak is so small that if I hold a finger on it it stops.
Also I noticed that scorpions aren't really made to work with the FAZR FE Kit? The instructions that came with it show them installed with the stock fender. The reason I bring this up is because there seems to be 2 extra parts that I have. A small plate that fastens on the stock fender and then there is a connector plate that connects the exhaust mount plate to this plate to keep a fixed distance between the tail and fender. How do I get around this problem?
Thanks a lot for your help,
M.
M.
