pic 2 and 5 are of the frame where it had to be cut so the undertail would fit, 3 and 4 are of the tabs i had to weld on for the seat to sit on and bolt to, the nuts are welded under the tab. 6 is the "trunk" if you shorten the exhaust and turn it so it fits with the undertail the pipe has to be rebent and shortened, so you have to cut the back of the trunk out so the pipe wont hit it. as soon as i get time im guna take it off and trim it a little more then fill it with fiberglass.
