Red Victor goes mental
Ridgeback
Wakin up the neighbours
Godalming UK
Don't know how much you know about this car,but it started life as a '70's Vauxhall Victor,with a 90 bhp 4 cylinder. After a certain Andy Frost got (ahem) tinkering it now boasts 2300+ bhp courtesy of a 572 ci Twin Turbo Chevy big block.fine you may be thinking,but this is a street legal road car,that runs on regular pump gas,is taxed,insured and mot'ed
It holds all sorts of records and is acknowledged as the worlds fastest street car. It pulls a 7 sec standing quarter,0-60 in 1 second and tops out at 233 mph.
Well it has undergone a bit of a makeover and is being revealed this weekend,at the Vauxhall VRX festival.The body has been tweeked,as has the engine,which now kicks out 3000+ bhp :eek: new est 1/4 is 6.3 @ 240.
Still fully road legal,still running pump gas. Absolutely mental! :D
Here's how the engine breaks down,for all you proper petrol heads :D
Specs as follows :
Dart big M block
Lunati pro series 4340 forged crank
Oliver billet steel rods
Diamond turbo pistons
Speed pro "Hellfire" rings
Aviaid 4 stage dry sump pump
Modified Aviaid oil pan
Altiss engineering custom oil pump drive,oil tank and breather can
Jesel cam belt drive
Don Bailey designed Comp Cams custom turbo roller cam
Comp Cams H/D roller lifters
Manton 210deg 7/16" ex pushrods,Comp cams 7/16" intake
Cometic multi layer steel head gaskets
ARP heads studs
Dart Pro1 355 CNC heads with Ferrea stainless intake and super alloy exhaust valves modified by RFD dvelopments
Edelbrock 454R intake manifold modified by Altiss for 2 x 1500cc Ford motorsport injectors per cylinder
Manley valve springs
T+D 1.75 shaft rockers
Ali rocker covers modded by Altiss
Custom 321 stainless headers by Altiss c/w2 x Turbosmart pro wastegates
Burns 321 stainless merge collecters and Custom 321 stainless 4.5" exhaust system
Turbonetics "Godzilla" BOV
Billet 2200cfm throttle body
Custom throttle body hat CNC'd by Taylor machine and finished by Altiss
2 x ARE cooling 12"x7"x 13""" Air to water cores,c/w 8 gallon water tank. Tanks fabricated by Altiss
2 x Holset 88mm custom hybrid turbos spec'd by Holset with inconel exhaust wheels
It's good to know that in this world of health and safety,electric cars and save the dodo,that someone still has the balls to build and drive cars like this ;)
Wonder what it does to the gallon ?? Not much i'd say:eek:
5mpg
[ame="http://www.youtube.com/watch?v=YtxfbxGz1u4&feature=fvw"]YouTube- Fastest street legal car[/ame]
