Need Help Radiator Problem
Yusuf El Safty
Egypt
I have an FZ6N 2004, Checking the radiator this morning found it got rust and lost some water, I filled it and started riding, when i reached destination and turned off the engine water bursted from somewhere under the seat, but no leak, I opened the radiator I found it lost like half of the water, seeking your advice.
Your radiator water recovery tank is under the seat.
Plastic with likely a black cap. Inspect there for a loose/broke/split hose going to it.
**I wouldn't ride it with that leak till you fix/replace the radiator. You'll destroy that engine real quick.
Your owners manual should show it's location.
