Beeg22
I am in the middle of converting and 04 fz6 to an 03 r6 front end, As for parts I started with 03 r6-forks, calipers, axle and bolt, wheel and rotors, and fender. I have mounted the forks, and went to put the wheel on and noticed that neither set of spacers will fill the void. Just curious if there is a place that makes special spacers for the conversion, or if I should just use common washers and split them 50/50 each side? If the latter of the two is there a set gap that needs to be filled or just till its snug?
