power commander 3 maps
expatmanxman
chesterfield (UK)
I have just fitted a PC3 USB, a decat pipe and had the standard muffler drilled. When I looked on the Power Commander site they don't seem to have many maps to download. Has anyone had the same setup and if yes what PC map did you use? Also are there other sources of PC maps.
Alternative is a rolling road session but I'd rather spend the money on other bits and pieces.
Drilled muffler makes an interesting noise, the bloke who did the work for me
(£40 to cut the end off, drill and reweld end) says he will fit bigger tail pipes if I want for no extra cost but it will have to pass track day noise tests so don't want it too loud.
I have a similiar setup, de-cat, drilled stock muffler and minor airbox mod.
I have had my bike dyno'd and have a custom map setup, you could try my map if you want.
Not sure if it'll do the job, with the difference in location ( Aus / UK ) and I have the airbox opened up a little.
PM me if you want to try it.
Mac.
