Beerdrinker
2^57885161-1
It might sound silly but I have a question and I can't find a satisfying answer for it.
I will add an extra headlight because I run lot of kilometers at night. I will also add a switch especific to this light. Now, what should I connect in the switch, the positive or the negative wire? And why?
In my old motorcycle, the same instalation, I had the positive wire, but is this the correct?
P.S. the switch is connected to a relay connected to the ignition and with fuse also.
Thank you!:thumbup:
Thank you!:thumbup:
